Does any one know if there is a mercedes TV tuner to plug into the compand system. How much does it cost and where can I find one. Or should I use any ordinary after market tuner?<p>C8Z6P6
Discussion Starter #2
There is an MB one. It is PAL (European standard) and requires the European COMAND software.<br> <br> If you buy it together with the car, it costs around 1000 $. If you want to add it later, you have to replace your wiring, install 4 antenas and replace the rear window. Labor costs (in Switzerland) would be arounf 3000 $ (and the interiour of your car would practically be taken apart and screwed together again). <br> <br> As COMAND 'senses' the add-on devices with the optical CAN bus, it seems to be impossible to add a third-party device.<br> <p>
