61 - 80 of 129 Posts
· Super Moderator
1986/1990 W126
Hello my dear friend.
I know the thread is old but maybe you may still help me about ntg2.5 latest firmware update.
I whant to do on my new car witch i buy recently. Thank you so much.
Hello
Can you help with the update? 09/29?
post:56
Step by Step.
Hello to both of you, and welcome to the forum.
· Benzworld Staff
Night Crew......2006 B 200 .....& Audi A6..
Thanks for pitching in here ianrandom. I've had the habit of waiting a touch with newbies and then adding ..
Please complete your BW registration. ===> user CP profile
click on your icon----> click on Account Settings---->
goto Account Details----> add vehicle details---->
ADD your make model YEAR ----> click save.
Hope that he gets his needed updates..
2008 E320 CDI 7G-tronic
Hello everyone!
As I see, this thread is a bit old, but with some remaining activity :D
My hdd in NGT2.5 just broke and I am looking for the full FW (or cloned image of hdd), so I could clone it to new hdd (already have the same hdd, as my NTG2.5 has, but from w221). Can someone, please, share a link of the image of 211's NTG2.5 hdd?
Thank you in advance!
· Benzworld Staff
Try asking here ?..or posted the same question ?..but maybe someone here can also give added input.
I don't think, that 221 owners would have an image of 211 hdd :D but thanks for the reply
Si quelqu’un a besoin de la mise à jour du firmware pour NTG 2.5 à la version 09/29 - dernière, je peux vous aider (ofc. gratuitement)
-PS: Si vous avez d’anciens firmware et cartes, les anciennes cartes ne fonctionneront pas avec le nouveau firmware.
Je peux vous fournir des cartes de l’Europe qui fonctionneront ( mais vous devrez sortir l’unité ntg 2.5 de la voiture et vous avez besoin d’un connecteur IDE vers USB.
[/CITATION]
Bonjour mocab180, je suis à la recherche d'une image clone complète pour mon HDD 40go neuf (vierge formaté en Fat) en remplacement de mon HDD d'origine qui est hors service.
Ma Classe B w245 de 09/2008 a le Command APS NTG2.5
Pouvez-vous m'aider please ?
Ci-joint mes photos
Merci
Cisco06
Hello mocab180, i search an image cloned off HDD NTG2.5 for my new HDD 40go. I also search an image of firmware 09/29. Can you help me please ?
Thank's so much
Cisco06
Hello all,
i have a MB GL 350 blutec 350 from US and like to apply EU maps and also update the radio to Eu standard in terms of frequences. I tried an update with burned ISO for 1649014600 versions but failed and "start" buton was not active.
Does anyone succeeded that kind of issue? Please find bellow my HW/SW versions and update screen.
Hi, did you manage to do it? I have exactly the same unit and have tried with the:
[CD-INFO];
CD-NAME 1718274559-0002;
and got the same as you, start button is not active.
Mercedes GL 320 CDİ x164 2008
Okay so my bit kindness for the day after having broken my head over how to update! I will explain this procedure as I went about updating my firmware:
1. Download the firmware from Mega link provided by mccab180 (Thank you!) - 756.92 MB folder on MEGA
2. Unzip the file (extract)and In there you need to edit the CD_INFO & CONFIG files with your ZGS number. My ZGS number is 1698700594 (no need for last 3 digits). To edit the files right click and open with notepad - you will see information as follows, change the bold number to first 10 digits of your ZGS Number. Now save the file
[CD-INFO];
# HU25 High ECE,HU25,HU25_VAN,
[1698700594-XXX];
# SW_TELEMATIK_BLUETOOTH_E53_31
0019025100-001 \HU25\092200\A001902\5100_001\;
# SW_TELEMATIK_GATEWAY_HIGH_E53_31
0019025300-001 \HU25\092900\A001902\5300_001\;
# SW_TELEMATIK_NAVI_HIGH_ECE_E53_4
0019025600-001 \HU25\093000\A001902\5600_001\;
# SW_TELEMATIK_AVC_HIGH_ECE_USA_E53_31
0019025900-001 \HU25\092900\A001902\5900_001\;
[CD-CONFIG];
[DOFLASH];
# Hardware from Harman/Becker
[1698700594-XXX] 0019025300-001;
[1698700594-XXX] 0019025900-001;
[1698700594-XXX] 0019025100-001;
[1698700594-XXX] 0019025600-001;
3) Format SD Card in Fat-32 mode and name this card "ALPINE_DVD"
4) Copy all files of CD A1718274559 into SD Card
5) Put the SD Card in slot of COMAND and go into expert menu (Red phone button + * + 6) and go to SDW menu. There go to software update, the Start button will now be active. Click Start to initiate the procedure (I did this with the car turned on, so that it would not stop mid-way due to weak battery). It takes about 15-20 mins for firmware to update
Hope this helps someone!
BTW - I have ordered a 2017 map update DVD off ebay (was significantly cheaper!) - I will udpate on here once I update the maps to tell you'll about it! I could not be bothered about doing the Hard Disk mirroring procedure!
Hi first,
I did everything as described above but now I have the problem that there is only "Software missing - Error on update - Error code: 0x 3 2 0 0". it no longer boots either. what can I do now. my firmware version was 29/09.
Thanks in advance
VW Polo 6R ;B180 CDI Sport 6sp '09- SOLD,
Discussion Starter · #77 · (Edited)
Im not sure, try the keypad combination menu for secret menu. if that leads you to the firmware update menu.
touching the HDD wont do anything, firmware is stored somewhere else on the device.
edit: try also burning the firmvare on cd and try that. you messed up the config
because the software is gone, the radio blocks the cd input. What do I do now? Mercedes dealer wants a lot of money for the software import.
Discussion Starter · #80 · (Edited)
Flash via Vediamo or Xentry online.
You have incorrectly made the config file and it corrupted your firmware installation.
- you have soft bricked your unit.
I dont know any other way, or where the firmware is located on the unit. I cant help you.
I'm 99% sure you can flash the firmware .cff file via Vediamo and fix your HU25. Find someone who does this in your country. ( Someome who does mercedes codings, and retrofits) They will know what is Vediamo or dts monaco.
