1 - 11 of 11 Posts
2004 W220 S320CDI
Hi
The trunk mounted Comand navigation DVD drive has failed (can't read DVD's) in my 2004 S320 CDI (W220) (European vehicle)
Has anyone ever swapped this drive out? if so is it an easy swap? anything to look out for before I get the tools out and will it require any coding when the replacement drive is installed?
And, yes before anyone asks I have tried a CD 'Lens Cleaner'
Any help advice or tutorials would be appreciated, thanks.
· W220 Moderator
Hi,
I've never changed a Trunk Mounted one, but I swapped a drive on a COMAND Unit (in Dash one), no coding needed :wink
Cheers Dave
Mercedes S500 - W140 && S500 W220.
It is much better to change the whole unit, rather than the optical drive.
the optical drive is mounted with special vibration resistant resin; which will most probably degrade if not lost totally.
not to mention, that balance will be out !
Hi
2004 W220 S320CDI
Do you mean this?
2006 W220 S65 AMG (1985 W123 300D - Sold!)
I replaced mine a few months ago. Comes right out with the special tool that slides into the two slots on the face plate. I had the old one out and the new one installed in less than 10 minutes. No need to remove the trunk liner. Just order the MB radio removal tool from Amazon or something.
Sent from my LG-H918 using Tapatalk
2004 W220 S320CDI
Discussion Starter · #7 ·
Thank you sir
2004 W220 S320CDI
Discussion Starter · #9 ·
Drive fault found!!!!
I successfully replaced the navigation DVD drive. Just for curiosity I opened up the faulty drive and discovered the probable cause of the drive fault.........water in the drive, as can be seen below.
I have no idea how water could have entered this area of the trunk, I will have to investigate further.
· W221 & Audio Moderator
2015 S550
There is also a vent in the left rear wheel well, behind the electronics racks. If there has ever been damage to the left wheel well area, the leak could come from there. In addition, the trunk lid seal could be leaking.
1 - 11 of 11 Posts
