Ronald, I hope for you that you sold it to someone with a 463 G-class...otherwise someone ...
Ronald, I hope for you that you sold it to someone with a 463 G-class...otherwise someone will have a problem with a navigation related speedpulse...
greetingz,
Member
'00 ML320 Elegance
Has to do with the CAN-BUS I believe...
Are you 100% sure the G500 Command System will not work in a w203, if true what exactly is the speedpulse issue?
Thanks,
Chris
The system uses data from the vehicle's network to calculate how far you've travelled, etc. Apparently the G's is different than the C's, and hence it won't be directly compatible.
