1 - 12 of 12 Posts
1996 E320, 2005 Toyota Camry
Does anyone have a defiinitive answer on how to find the interior color code on a car AND a listing of those codes for an '85 190D? Thanks.
Hemersam
92 190E 2.6, 01 BMW X5, 03 BMW 330i, 73 MGB, 79 Triumph
Hemersam
Should be a data plate riveted to the radiator top panel. The 3-digit codes can be deciphered using one of the FAQs.
Or PM me your VIN and I'll look it up using the MB-EPC system on-line.
190D
cloth, leather, vinyl, velour options
I believe first two digits for material, last digit is color
For vinyl material:
151 black
152 blue
153 N/A
154 tan
155 cream
156 olive
157 red
158 gray
159 N/A
color codes
I should have mentioned that my 190D is a Euro; does this change any of the "code stuff?" Thanks.
Hemersam
Hemersam
Nope, the EPC is global. I received your VIN, it does not decode in the EPC. The only thing it knows is that it's a 2.2 diesel.
There are three-digit sets of numbers on the metal plate attached to the upper radiator support: 122, 175, 737, and 355 (the latter two I doubt). Does this answer the color code question? Thanks again.
Hemersam
Discussion Starter #11
c
MBeige: thanks much for your reply. The numbers match for creme beige (which it probably is), but the interior almost looks like 165-parchment. Well, pictures of colors aren't always accurate, plus the fact that the parchment color wasn't used until '93, so I'll go with the creme beige you showed. Thanks again; I appreciate it.
Hemersam
1 - 12 of 12 Posts
