Addition to Post...
The Cold Start stumble sounds the same as if a Vac Hose is disconnected when the Engine is warm. I've sprayed both Carb Cleaner and Brake Cleaner on all of the Outside/Inside Vac Hoses in my attempt to locate a Leak somewhere, but I can't locate one.
Also, with the Engine running, but still Cold, I disconnected the Plug to the Cold Start Injector. No change. I had assumed that this Injector would be continually spraying Fuel into the Intake, while the Engine was Cold. I'll do a Voltage test on the Plug and see if there is any output.
Thanks,
Sam
Thanks,
Sam
