1991 300SE W126 Collector owned, maintained 90k mi
I have a 1991 300SE w/110k mi. I have replaced plugs, cap, rotor and O2 sensor in the last few weeks. I have noticed this pattern. When I start the car in the morning it idles and accelerates smoothly. When the temp indicator hits 80 deg C it will have a rough idle and sputters upon acceleration. I'm thinking there is a cause and effect here. I'm targeting the rear temp sensor (4 prong) that signals the ECU. I have a feeling it's too rich when this happens. It has nice acceleration at hiway speeds, just idle and lo speed there is a stutter. Any thoughts?
1989 mercedes 420 sel & 1995 volvo 850 t5 (just in case)
Did you check the condition of the ignition leads, i had a similar problem with my 126 and the Volvo, while the engine is cold it's smooth(er) without misfiring after a while when it warms starts to miss, for the volvo i replaced the leads from the spare car and the Benz I brought new Karlyn leads.
The ignition leads should measure around (give or take a few ohms) 1000 ohms for all w126s.
