1 - 14 of 14 Posts
2003 500sl
I have a 2003 Mercedes SL 500 I did the coilovers started the car and nothing is leaking I didn't change the pump my question is if one of the lines breaks from the ABC system will my power steering go out or do I have to change the power steering pump
Current: '07 SL550, '06 ML350 - Past: '99 ML320 (Sold), '98 SLK230 (Wrecked), 05 SL500 (Wrecked)
So, when you did the coil-over modification, did you leave the ABC system in place? What did you do with the lines that were going to the original shoks?
2003 500sl
there just hanging there lol they r not leaking there compress finings so oil will not leak out I been driving the car since sunday like this no leaks my concern is if some goes wrong like a line breaking from the abc system will I lose power sterring that's what my concern is
I suppose you could replace the tandem pump with a basic power steering pump. Since there was no "standard" pump for the R230, you'll have to get one from a different model. l think you'll probably find that models that offered the ABC as an option like the S500 or the CL class were available with standard power steering pumps which will probably fit.
I'm sure if you do a search around here, you'll find that information.
BTW, did you use the sway bars on your mod, or just replaced the shocks?
99 E320 4matic Wagon, 2003 c320 4matic wagon, 2004 CLK 55 AMG Convertible
dudeman, I could really use an answer to the power steering pump question when coil over is used. I have read s500 and ml500 of the same year. Will the hoses reach and fit?
2003 500sl
sry for delay I am still driving the car with the original pump in there still no prob but tomorrow I will be taking out all abc fluid out and leave the pump and see if power steering still works I didn't put sway bars in the car rides the same I have a settting on coilovers for soft or hard rides great will let u know what happen when I take abc fluid out
Jimmy,
Thank you for help in making this project a reality and for saving lots on r230s heading for scrap. Do be careful with removing the pentosin. What would you replace it with?
I wouldn't do that. Read up what happens to the tandem pump when you loose the ABC fluid. Most of the guys here that had a problem with a broken ABC Hose and total loss of fluid, ended up up having to replace the pump, so you taking out all the fluid would end up with the same results.
Just replace the pump with a standard power steering pump from an ML500, CL500 or S500.
Speaking of Sway Bars (or lack of them), have you put the car into any high speed turns or emergency maneuvers?
The ability to dial in a soft or stiff ride, is not a substitute for the sway bars.
Dudeman,
“Just replace the pump with a standard power steering pump from an ML500, CL500 or S500”
Do you mean the same year? Will they all fit? Will the hoses reach?
Bless you in advance
I don't know if the same model year is required, I don't think so, but the person that could probably help you with that question is Rodney (Rudeney).
2003 500sl
Discussion Starter #12
I took out the fluid from the ABC system I left the original pump in there so far so good drove the car for 2 hours still have power steering I got the car up to 80 on the highway no shaking smooth ride and as far as the ABC light the infamous red light on dash what I did was connected all three wires from each original shocks together and abc drive careful light is gone
Sorry, I can't tell you what pump to use. There was never an official non-ABC PS pump for the R230 other than SL350. it was not sold in the USA, and the PS pump was specific to that model - it shows no cross-references to any other cars. I have heard that the PS pump from an SL500 will work. My guess is part number A0024668601 or A0024668701 - but that is just a guess!
1 - 14 of 14 Posts
