1 - 8 of 8 Posts
2001 e430 4matic
toom the advice of ohlord and got the scanner---5 codes come up---
p0300
p0308
p0110
p0100
p0221
erased them, changed the plugs---so far no new codes-----
by door locks used to shut automatically upon driving, which they dont anymore--is this related
1994 E320 Wagon,1999 E320 Wagon,2000 E 320 Wagon, MGB Track/Rally, ,1988 300E ,more....
That is
a feature in the key,Someplace in the manual it should tell you how to program the key by putting it in the ignition and in position 2 pressing and holding one of the buttons on the key to activate the over 9mph auto lock feature.
It's sort of like the other procedure with the key that makes all the locks open at the same time or just the drivers door.Look under key settings in the index.
ohlord:bowdown:
To acitvate: With key in steering position 2 hold upper portion of the dashboard central locking switch for a minimum of 5 seconds.
To deactivate: With key in steering position 2 hold lower portion of the same switch for a minimum of 5 seconds.
See
who needs the manual when we have the Musikmann:thumbsup:
ohlord:bowdown:
musikman thanks very much, what would i do without this forum
You are certainly welcome and thanks for the mention. I guess we can assume that the activation procedure worked for you?
1 - 8 of 8 Posts
