2002 Black SL500, 2000 Azure blue SL500, 2005 Silver (A209) CLK500
This has been ongoing...
Perhaps an electrical expert knows....
Instrument cluster...turn signal on....digital odometer/trip meter/outside temp gauge/and 4 way flasker above the climate control blink.
Took the cluster out...installed it in another W140 and no blinking. Took that donor cluster in installed it in my W140 and it blinks. So..it's not the cluster...sounds like a ground issue.
Ideas as to where to start? So many ground wires to check....
Thank you all!
99CL600,98CL600 Swiss import,R230 SL666, EURO1985 280 CE & XR600R Desert killer
damn I have same problem I wish somebody help us with that also now on my cluster soon as I turn left signal the right signal blinks WOW thats CRAZY
2006 S500 AMG Wifes Rig Hillbilly Girl 02 ML320
Mr PHamiton here on the boards can answer your question on the blinking dash!!
Smokie
Smokie
Yes...phamilton is helpful....he mentioned the "3 caps" needing to be replaced.
Problem is, what 3 caps does he mean?
Secondly, it's not the cluster....it has been ruled out has the problem by using another cluster (3 different clusters not blinking in other cars but blink in my car...ground issue) out of a W140 that does not "blink."
It's a ground issue in my opinion..but where?
84 500 SEL ...94 S420..... 95 S500.... 96 S500 95 S600
check your tailight bulbs
Check all your tailight bulbs,had the same problem because someone put the wrong bulb in the wrong socket..remove each one and look inside of the sockets...
