How many bulbs, where to buy them, should I make it white, red, blue?
Thank you very much for your answer.
Blue looks good, thats what I did. I just sent the link for the bulbs to cjshade, he can tell you exactly which ones to order and how many - I dont remember off the top of my head..
CJ... thats you cue..
Cluster light Thread
Here's a link to the Thread on the LED's. I did not have good luck with the LEDs and went to the glass blue ones. It is a bit harder to see the Blue in the daytime. The LEDs may be brighter if you can get them to work. The Thread chronicles the hassle I went through.
You will need a total of 5, or 7, 1.2watt lamps depending if you want to change your turn signals out or not. You will also need qty. 2, 2watt bulbs for the background ilum. I still have to buy those for ours.
http://www.benzworld.org/forums/w202-c-class/1407655-odometer-went-dark.html
Good Luck!:thumbsup:
C as in 220
