When I took my 350SL out for first time this year , she ran perfectly, but I noticed a clunking sound when driving over bumps.
First, I tidied up trunk and made sure jack was properly clamped.
Noticed trim behind door on driver side low down was loose. Fixed that (screw had rusted out)
Tried driving with windows up and down. Noise virtually went away when windows were down. But back again as soon as I raised them. Repeated this several times with same results.
Removed door skin on driver side. Nothing loose! Checked glued on guides and they are still fine. Broke some clips getting skins off, so next job is to fix those. But hard to understand why lowering windows causes noise to almost go away.
Next possibility are Sway Bar links. Or maybe shocks are loose? No noise though if I bump car up and down in garage.
Exhaust doesn't make any noise if I jiggle it around.
BTW, soft top is up. May be back for more ideas
