2003 E320
Just purchased a 2003 E320, with 73K miles, in terrific general condition.
I noticed that when barely rolling (say, in a parking lot, after backing out of a space), if I shift from reverse to drive (or the other way around) the car makes a fairly loud `clunk' and shudders a bit, if the car is not completely stopped. Otherwise, the transmission seems to be operating perfectly.
I've never experienced this with any other car with automatic transmissions, over many years of driving.
Is this normal, meaning you cannot shift from drive to reverse unless the car is 100% stationary? Or, is this an indication of a problem?
A hint: The dealer said the car had some `vibration' when they took it in trade, and replaced the engine mounts. Could the cause of that problem be related to the cause of the `clunk'?
I am new to Mercedes, so will appreciate your help.
Thanks!
Zotye Auto 1.5T T600 2016
Welcome to Benzworld. Please complete your profile as this will help members give you the most accurate answer to your questions. Location is also important when we need to help you find parts etc. This forum is for introductions only and all questions should be posted on the appropriate sub forum for your car.
At the bottom of the page you will find forum jump, click on this and view all the available sub forums.
For FAQ see the Benzworld help section here:
BenzWorld Help - Benzworld.org - Mercedes-Benz Discussion Forum
Regards
