CLS500 205
Hi all,
my engine management light has come on, had it plugged into diagnostics. Two codes popped up, one was to do with the EGR valve P2001
The other is P2007-8 pressure sensor signal implausible, the one that is worrying me more is this code. Does anyone have any advice on what to do with this please? Can it be fixed or will i need to replace something ?
Many thanks everyone
CLS500 205
Discussion Starter #2
sorry all, i forgot to mention it's a CLS500. 2005. 54,000 miles on the clock 5 litre V8
2000 and 2003 and 2004 ML320 and ML350
Did you ever solve your problem? I have this code (p2007-008 on a w163) and can't find information on it. Thanks.
I realize now that my ml320 does have a MAP sensor. I was confused a bit because I was under the impression that cars had either a MAF or MAP but not both. Adding to my confusion is the fact that ML320s in other markets have their MAPs deleted at the factory and thus most parts sites do not list a MAP as a valid part. The Mercedes dealership sites do however. Thanks for the response.
