Hi All,
mucking around for a while as to how to set the clock, no success yet (clk 320 2003).
Any help would be appreciated.
Cheers!
:confused:
Hi,
When you are stoped, on screen find "settings can ne change at standstill . Press R to reset.." There you can adjust language, temperature to F or C, clock time, clock format etc..
If you have the Command system you have to go through that menu to adjust both the digital clock on the screen and the analogue clock on the dash(syncs automatically).
2004 CLK 240 Coupe
Is this the 'End of Summer-Time' routine...:)
With COMAND your clock should automatically correct itself by one hour. Mine does.
Discussion Starter · #5 ·
Hmm, mine doesn't .. I live in Australia if that matters.
Looked at Command instructions but couldn't find clock adjustment .. will re-visit. :surrender:
