I use C220, 1994
It happen whenever I didn't start or start the engine. The situation is...
When I turn on the headlight at first or second position, all warning sign ABS,washer.... (which should show before I ignite the car) happen for a second and the clock set to 0.00
It happen sometimes, so I feel to confuse to check.
I check the fuse, relay it seem ok. Does this problem come from instrument cluster electric(circuit) board?
Thank you
Discussion Starter #2
I found how to solve, the problem come from instrument cluster. the new one is $500 while a used is $250. I walked along at second hand shop and found $180 used only board circuit. I took it and ask them to replace with my current board. Now it work ok.
