1 - 20 of 41 Posts
350 SLK
OK, daylight savings time is here and I went to change the clock on the instrument panel. Since I have COMAND, I have the instrument panel clock set to sync with the COMAND clock. I set the COMAND clock ahead 1 hour yesterday and, as of this morning, the instrument panel clock has not changed. Is there a step I am missing?
2005 SLK350 2011 GLK3504X 2006 ML350(selling when GLK arrives)
I don't have COMAND...[B)], set mine via the wheel buttons and hit the reset on the left of the left speedo ring...that worked...[;)]
350 SLK
Motzkoman - 4/4/2005 2:54 PM
Hmmm....I guess that would work if I set the instrument clock NOT to sync with COMAND. Still iffy about the Reset button as I am afraid it may reset something I don't want reset[:0]I use it to reset the trip computer every time I get gas and always wonder what else it may be changing.
Also, when you scroll through the mileage info in the instrument panel there is one reading that shows "range". I thought that was how many miles I had left before I ran out of gas but I currently have 1/4 tank left and "range" is showing 50 miles. I know I get more than 50 miles on a 1/4 tank. Am I wrong and "range" means something else?
R171 200K
I had this same problem getting the instrument panel clock to change. The step you are missing is that you have to hold/press the button on the side of the panel after setting it electronically.
350 SLK
R171200K - 4/4/2005 3:47 PM
Thanks! I guess you have to use the "reset" button for any change on the instrument panel.
SLK 350
I do not have comand. I'm trying to set my clock but the + and - buttons on my steering wheel don't do anything. I don't know how to get the clock menu to appear. Have I missed a step?
2005 SLK 55 AMG
I have the clock sync'd and all I did was change the time on the screen and pushed the OK button and the little clock just whirled ahead an hour right away.
SLK 200, Golf V GTI
Mel,
It certainly isn't easy to set- From memory this is what you have to do.
1.scroll with far left menu buttons to get to the "settings" menu.
2.Press the up or down arrows also on the left of the steering wheel to enter the settings menu.
3.Scroll within this menu using "+" and "-" on the far right until you get to "time/date".
4.Now use the arrows on the left to navigate within the "time/date" menu. You can change any of the highlighted numbers with the "+" and "-" buttons on the right (as I think it indicates)
5.Once you've set the clock, Hit the "R" button on the side of the instruments! (It took me a few trys to work out this was the only step I missed.)
Hope this helps
350 SLK
CP1 - 4/4/2005 4:18 PM
That's it!!! I did not push the OK button for the COMAND screen when I changed the time in COMAND. Thank you!! I swear MB needs a manual to explain the manual[xx(]
Duo-Art - 4/4/2005 3:58 PM
Mel:
I originally had that problem but played with it until it worked...it says on page 134 of the manual after getting to time/date with the + or - buttons, to press the up or down arrow button repeatedly until the "clock, hours" shows, then do the same for "clock, minutes"...[:eek:)][:eek:)][:eek:)]
I should add that the time/date is in the settings menu (left most buttons to get there)...[;)]
350 SLK
Discussion Starter #13
Motzkoman - 4/4/2005 4:55 PM
Mel:
????? I think I'm getting dizzy. I thought the +/- buttons were the up and down buttons but obviously not. Are the up/down buttons to the right of my COMAND screen under the number pad? If so, I am not sure what good it is to have the +/- buttons on the steering wheel (which I thought were there for convenience) if you still have to reach over to other buttons to complete the step.
350 SLK
Discussion Starter #15
MTT - 4/4/2005 5:22 PM
Mine was set automatically from winter to summertime. I did not have to adjust it in any way. :)
Can you please enter your location in your profile (It appears I have taken over DuoArts role with this location thing) [:I]
I take it you are not on daylight savings time?
SLK 350
The other option is to lay out a course directly into the sun at maximum warp and at the last second engage full reverse thrusters and the sling slot effect should propell you into the future one hour, plus or minus a nanosecond. Oh wait, that was star trek or something.
2005 slk 350
roadsterboy - 4/4/2005 9:17 PM
I tried that, it doesn't work.
SLK 350
jono_m,
Thanks for the step by step. It took a few tries but my clock now reads the correct time. I like the digital in my Honda better. Both the driver and the passenger can see it and it takes less than 5 seconds to change the time.
Mel:
Maybe if we practice, we can be ready for the last Sunday in October when we go back in time...[:eek:)][:eek:)][:eek:)]
R171 SLK200
MTT - 4/4/2005 8:22 PM
Mine too! I was pleasantly surprised to see it had changed itself.
1 - 20 of 41 Posts
