1 - 12 of 12 Posts
CLK350 DROP TOP
I just bought a w209 convertible and i replaced the fog lights with led lights.
but they will not come on and stay on when you set the switch to them.
They only flash for a few seconds like Christmas tree lights do. What could be the problem? Or can i just wire them to the headlights for them to work?
2005 CLK320
They don't draw enough current you need to add a resistor in parallel or reprogram the front sam controller for lower current.
Sent from my SM-G892A using Tapatalk
2005 CLK55 AMG Coupe ,CLK320,Former,C180 Kompressor,Jensen Healey,Ford Capri V6,Alfa GTV.
Your car runs a CANBUS system ,,which monitors resistance on all circuits..your new led's have different resistance to the original bulbs.
If you replace any front lights such as Park lights or fog lights ,,you need to use CANBUS Error free / compatible led's.
or add a resistor as mentioned above ,,
it is usually easier to buy 'error free ' bulbs .
CLK350 DROP TOP
Discussion Starter · #8 ·
Ok were can i find what i need to buy it ?
CLK350 DROP TOP
Discussion Starter · #9 ·
Oh wow were can i find error free LED fog light bulbs for my car ? Hell that sounds a hell of alot easier to do !!!!
2005 CLK320
Ok my vin is....
WDBTK56F18F251763
I can confirm your headlights are directly wired to the front sam, best way to calculate the resistor is to measure the current on the original bulb, then measure the current of the LED on the bench wih14V.
If you don't know how to calculate it post the measurements.
The so called CAN eliminaters don't always work and a resistor is cheaper.
Still best way to do this would be reprogramming the SAM instead of burning off energy.
Where in the US are you I can may point you to somebody that can do the programming.
Paul
2005 CLK320
Im in Cleveland ohio paul do you know of anyone that can do all that and get my fog lights working properly?
I did date a girl from Cleveland but I dont think that helps, check the indy shops.
If you find one and they dont now how to do it I can help.
You could get a Chinese clone sds but it will set you back $600 to $800
1 - 12 of 12 Posts
