Clk320cab wheels&tires
604 Views 5 Replies 0 Participants Last post by  carjunkie
G
Does anyone know this setup will fit clk320cab without any modification.<br> 18x8.5 35mm offset with 225-40-18 Front<br> 18x8.5 35mm offset with 255-35-18 Rear<br> <br> Thanks in advance
G
The front would look perfectly line up to the fender well but the rear.......................
<br> would look to much tuck toward inside the fender well. I am using Carlsson 18x9 et 35 with 245-35 tires and plus H&R 15mm spacer to make it the wheel look line up to the fender well, like the front.
G
Btw, my car is already lowered with Eibach springs.
G
Re: The front would look perfectly line up to the fender well but the rear.......................
Thanks Linh<br> <br> Where can I get those spacer?<br> Is 5mm spacer will be OK or need to be 15mm like your?<br> <br> Thank You Again.<br>
G
Ddang, if your car is lowered, then 15mm is fine but if it not lower the 10mm.......................
<br> Autoclass.net give you the best price for only $100 (spacer and longer screws).
G
Re: Clk320cab wheels&tires
I have Carlsson 18x8 with 225/40-18 in the front, and 18x9 with 255/35/18 on the rears. The car is not lowered, and rides well. I did not have to roll the fenders.
