New to the Car, and I have no Manual for this 2000 CLK 320....
1) I was able to release the Fron Hooks and slightly lift it..
2) I try to activate a Then Red Switch near the Auto Tranny Lever...and nothing happens..
How does one get the Convertible Top Down..
Gary
2002 clk 320
Once you have un-hooked the front and lifted the top, pull up the red switch and it sho...
Once you have un-hooked the front and lifted the top, pull up the red switch and it should work.Also, make sure your key is turned to the third slot (right before starting the car. And make sure that your trunk is closed.
Tried that, and all I get is the four windows coming down.... I appreciate the come back...
Tried that, and all I get is the four windows coming down.... I appreciate the come back on the Response.
Gary
Del Mar Ca
CLK 230k Cabrio
In the boot there is a plastic 'cover' if you will, lets you get more in the boot when the...
In the boot there is a plastic 'cover' if you will, lets you get more in the boot when the top is up. if this plastic cover is not pulled back, the top wont go back.
Also, you have to keep the red switch pulled, as soon as you let the switch go the process stops.
