1 - 8 of 8 Posts
G
Has anyone had problems with his/her CLK pulling to one side when driving? I've had mine in the shop twice to fix the problem. My dealer says that my alignment is dead center. He installed a cam kit to help alleviate the problem. He thinks it's my tires (Michelin Pilot Sports), but I don't want to spend $$$ considering they've still got a good 10k miles left in them. Any ideas?
G
My dealership replaced my tires for free due to abnormal wear, get it free..
You have one set of full covered tires.
G
Discussion Starter · #6 ·
Could be that your wheels aren't balanced or you have an irregular rim..
You'll know when you have your wheels balanced. I suggest having it done at an independent wheel shop and if they confirm that it is irregular, then have your dealer replace it under warranty. <br> <br> Your car shouldn't pull to the right except if you have really really bad tires.
G
Discussion Starter · #7 ·
Re: Does it pull to the right when braking or does it just generally pull to the right ?
Have you checked tire pressure? May have picked up something on the road that is causing a slight air leak. Spoken from experience...
1 - 8 of 8 Posts
