i hsve a clk 55 and looking for 8 1/2 18 front and 9 1/2 or 10' x 18 rear will they fit and what is the correct offset, thanx
Discussion Starter · #2 ·
Depends on which wheel and its offset....<br> 8.5x18 235/40/18 front and 9.5 or 10x18 255/35/18 rear should be no problem.....<br> <br> <p>as0011bob2li.bc.hsia.telus.net
I think ...
That you would probably be better off with a 18x8 35mm offset in the front using a 225/40-18 tire and a 18x9 with a 30mm offset using a 255/35-18 tire size in the rear. The reason I suggest this application is because the 225/40-18 and the 255/35-18 have approximately a 25' diameter just like your original tires.<br> <br> Luke<p>tiresales.tirerack.net
