G
Discussion Starter #2
Would they fit a 320 cab neone?
Im also in NJ Stefan. <br> <br> How much did they lower ur car.<br> <br> Do u have the car with the Giovanna whls?<br>
G
Re: Would they fit a 320 cab neone?
I'm not sure if it will fit a 320. You would have to do some research. It lowered it about 1.5'. Yes, I had the CLK with Giovanna Essens.
G
Re: Would they fit a 320 cab neone?---In the begining,
H&R had just one part number for coupe and cab; now they have several for coupe and cab, 6 cyl and 8 cyl. You can check the part number on their website. The pieces will probably 'fit', but that doen't mean they will 'work'. Most likely, the v8 pieces would not work well on the 6 cyl, primarily due to the wieght differnce. You probably would not get the ride height adjustment you want. Check out the pn's and see. Hope this helps; I only know because I went through 3 sets before getting it right. allen.
