What width's did you get ?
For the 8.5 wheel, you need an 8-10 mm spacer.<br> For the 9.5 wheel, you need at least a 12mm spacer.<br> <br> Also the bolts are different so you would need to force the lugs in the first time to make them work. The stock CLK lug bolts are 12x1.5 The AMG CL wheel uses 14x1.5 bolts.<br> <br> H&R sells spacers but I'm not sure what widths they offer. You could probably use the one's for the Audi A4 as well since they're the same bolt pattern.<br> <br> I used to have these wheels on.<br> <br> Good luck and post pics.<p>gk.un.org
