1 - 8 of 8 Posts
1997 CL500
I have reprogramed the Climate Control Unit from my 1997 S-Class, to display the tempeature from fahrenheit to celsius, and it works well;BUT ever since i did this change, the Back Light of the Climate Control Unit does not work when i turn on the lights. The interesting thing is that when the ignition is off and i press the REST button, the unit turns on and so does the Backlight. What could be the problem ? Do i need to reprogram something on the Climate Control Unit ? Obviously the Light Bulbs are still working.
Does anybody have a list of the Numerical Values and Preliminary Settings for those Climate Control Units ?
What could be the problem ? Any help will be gratly appreciated.
nothing broken. finally!
Yes you need to reprogam it
you might have changed the vehicle type which may result in it not picking the signal to illuminate
i had the list... uhm.. hang on. i should have saved that
ps. and now i can't find it. it was an obscure pdf document, takes some googling to get to
1997 CL500
if you could find it and post, that would be amazing.....
1998 140.070 CL500, 1966 406.121 U65
Keeping it to the same thread might help?;
http://www.benzworld.org/forums/w140-s-class/1550563-i-have-question-do-guys-know.html
You might have been able to tell the Climate that you want C instead of F, or vice-versa,
but at the same time, you implicit tells it, that it is a <1997 car...
I do not know how to change it for a 1997, but I think, if you tell the Climate, that it
should get C or F from the Cluster, P1 as 72, it will also get the illumination information
correctly.
I clearly states, that for a 1997 model, P1 should be 72.
br,
syljua
1997 CL500
Discussion Starter · #6 ·
well, i managed to reprogram the Climate Control to its original settings, including from celsius to Fahrenheit, and now the Backlight is working. I guess because the instrument cluster shows the outside temperature in Fahrenheit, the Climate Control has to also inorder to accept its signal. Is there a way to change the outside temperature display in the instrument cluster from Fahrenheit to Celsius, so that the Climate Control Unit will work in Celsius with the Backlight ?
I do not have the answer, but reading this, at the bottom;
STAR TekInfo
its clear that the switch information C or F, is sent by the IC down to A/C via K1.
So, it must be programming of the IC, but I cannot find any instructions on that
there. I will have a look in the DAS system, but I believe I have tried that before
without finding anything, so maybe its just a version-coding possible when you
replace and install another IC...
br,
syljua
1 - 8 of 8 Posts
