2000 e320
2000 E320 at idle code 23 battery voltage 33 (%) code 24 battery voltage 13.5 Does this sound normal? thanks
What codes are you talking about?
13.5V charging on climatronic is good as it shows about 0.5V less than on battery clamps. Still good idea to confirm it with voltmeter on the battery.
1998 E320 base sedan @ 160kmiles
Normal. code 23 is the illumination percentage of the backlight of the climate control. Does not really affect what you are looking for.
You should really be looking at item 6 for the coolant temperature and monitor the rise of coolant temperature from cold (ambient), after you start the engine. The instrument panel gauge gives you a rough estimate but item 6 in the menu gives you what the engine computer sees.
At 10 degrees C of ECT (50 deg F) , the rpm should go down to 800 to 1000.
