1 - 9 of 9 Posts
1994 S350, 2001 CLK320
Good Morning-
Texas weather has been nice till this week when we got our first freezing temps.
My 1994 w140 climate control was not up to heating the cabin sufficiently. I ran the sensor value test.
Results:
est Step Sensor Value Display
1 73 In-car temperature sensor w/ aspirator blower (B10/4)
2 72 Outside temperature sensor (B10/5)
3 86 Left heater core temperature sensor (B10/2)*
4 87 Right heater core temperature sensor (B10/3)*
5 35 Evaporator temperature sensor (B10/6)
6 87 Coolant temperature sensor (B10/8)*
7 11 Refrigerant pressure in bar (06 = 6 bar)
8 14 Blower control voltage from B(min) - 60(max)
9 20 Software status
Also, performed flap test and found 3 to 4 of primarily driver side flaps did not seem to operate by ear. So, I turned heater on and checked both sides of compartment for air flow. I found that I was not receiving heat from most driver side vents and if any air flow was found, it was non-heated air. Passenger side vents were operating and I could feel heat. Turned on the red button on center vent and received heated air on passenger side but none on driver side.
My questions are:
-the above sensor values look correct except #5. Do I have a evaporator sensor out?
-Is the non-performing driver side attributable to a non-functioning duo-valve or possibly a Y11 vacuum block malfunction?
Those are my questions from reading through the archives. Any help will be appreciated.
Mike
W140 Mercedes 500 SE, 1992, European, 440.000 km
maybe evaporator sensor is slightly non-accurate but it is always ok to be between 3 -6 °C when AC is on.
35 °F = ca 2 °C
but evaporator does not have much connection with heating so forget it for now. First thing which i would do is HVAC self test (find instructions in this forum under advanced search). then write down all errors (if any) and delete them. turn on the car for several seconds, turn it off and repeat the test and see which errors are present now. these are reliable.
most probbaly your duovalve is bad. if you will get an error for it then you know it is time for new one.
Discussion Starter · #5 ·
samosali - Thanks for the info on the evap sensor. OK, will perform test this weekend and clear errors from CC.
nhzruthless818 - Turned defrost on this morning. Good airflow from driver side windshield vent but not so much from passenger side. Air was cool, not warm on driver side.
Thanks to both of you for replies. Will report back what I find this weekend.
Mike
Discussion Starter · #6 ·
Ran trouble codes today. only code I received was EO 43 (A/C system temp sensor (B10?8), open or short circuit). I cleared the code. Would that affect air flow from vents, also?
Mike
93 500 sel - 95 s500
When I had one sided heat I replaced the Duo-Valve and it fixed my issue.
Good luck!
This is reasonable. In addition if temperature sensor makes problems it is very cheap to replace it. So in your place i would replace duo valve and test temperature sensor. There are three of them in my car, so make sure you will test the right one. Briefly, it has two pins and you should measure different ohm impedance at different temperatures. Roughly it is ca 200 ohm for warm engine and several kohm for cold one.
you can also test your duovalve impedance. it is hard to test it mechanically unless you open it.
Discussion Starter · #9 ·
Update on climate issue.
I replaced duo-valve I received from nzhruthless. That fixed my heat issue since one side was blocked. Then I replaced 3 actuators behind the dash to repair my vent problems.
1 - 9 of 9 Posts
