2004 CLK500
I can't seem to find anywhere in the forums where the same issue has occurred so here goes.... I cannot get my EC mode to come on..... I also cannot get the air vent direction control button to turn of the auto climate on the drivers side... it works perfectly on the passengers side. I believe there was a reset I did before to fix this but cant get any of the resets I have found to work. Thanks a million!!
2000 CLK430 2010 S550 4matic
Is possible, although stating the obvious, that the unit is shot. Unfortunately not a cheap part but they can be rebuilt. Also check eBay but remember they have to be coded for specific cars. You can do that yourself - press and hold the rest key and write down the 42 and 43 values before you pull it.
