1987 Mercedes 300D Turbo
I have a 87 300d and the climate control has a mind of its own. I replaced the vacuum solonoid bar and its still not working properly. When i set it to defrost in the heat setting it blows cold. It also doesnt blow from the middle vents in ANY setting. When any of the other vent selections is pressed it just blows out from the two side vents and floor vents. Im thinking there is a vaccum diaphram problem or mabey the control unit is on the blink.... It there any diagrams available or suggestions. Anyone else have this problem?
2013 E350 sedan, 2013 E350 cab, 1993 400E sold,1999 ML320
Do a search this is a common issue having issues with climate control. Center vents only open on white to blue setting for A/C and cool air. Defrost is only side vents and winshield. Double filled arrow is winshield sides floor and rear floor. Everything else is sides and feet, again unless in white or blue for a/c and cool air. If your vacuum pods are toast ( hoping you have already tried the thumbscrews on the vents themselves) then look up ps2cho's thread as he has completely refurbed his whole a/c system and pods (which requires pulling dash out).
