1 - 10 of 10 Posts
08' C-300 AWD SPORT
I followed Youtube videos for resetting the Service A steps but cannot get it to work. I am at the trip screen but when I press the buttons as mentioned below I can't get into the screen: step 4,5,6 I can't get to service menu.
  • Close all doors, windows, hood and trunk
  • Turn the ignition to the position 1 (If your vehicle has a Smart key button, press the “Start” button once without touching the brake pedal)
  • Press the system selection button (house icon located on the left of the steering wheel) repeatedly until the menu item TRIP is highlighted in the multi-function display. Within 5 seconds, press the OK button.
  • Press and hold the (ACCEPT CALL) button for a second
  • While holding the (ACCEPT CALL) button press and hold the OK button.
  • After several seconds the service menu should come up.
  • Scroll down and select the ASSYST PLUS
  • Turn the ignition to the ON position (position 2 or press the “Start” button once again) without starting the engine
  • Select FULL SERVICE
  • Scroll down to select CONFIRM SERV
  • Select appropriate OIL GRADE being used
  • Select YES and confirm it
  • Turn the ignition off and then start the engine to verify the indicator has been reset.
08' C-300 AWD SPORT
I dont know what I am doing wrong but I have been following these steps and cant advance to the assyst plus screen. ANy advice. Thanks
08' C-300 AWD SPORT
Any advice I don't know what is going wrong I can never get the assyst plus screen. Are the steps missing something.
For one thing... you're in the wrong forum... you have a w204 (according to your profile) and you're posting in the w205 forum. You may get an answer in the proper area.
2017 C300h estate.
I think you are holding the call button too long before you press the OK button.
Try pressing the OK button as soon as you have pressed the call button.
you can check youtube as well for instructions.. I had one video stating to hit Call and call-end and OK .. that worked for me.. (maybe call end wasn't needed.. but didn't hurt)
1 - 10 of 10 Posts
