1 - 14 of 14 Posts
W203, W211, W212
Ebay also. Note there are two kinds - "crytal clear aka euro" lenses like your headlights and "reflector lenses" like your stock orange bumper lights. Your choice what look you want.
2005 C230 SS
I saw it on ebay for $38.
Does these lights suppose to come with Bulbs???
please advise, thx!
2005 w203, 2013 Town & Country
Mine did come with amber bulbs from procarparts -
make sure you use a towl to cover your bumper when you remove the lens as you have to push back a little hard, and pull out to remove the housing...
i bought the crystal clear ones and spray tinted them black
jake
2005 C230 SS
Hey BF_JC230, was it an easy process & did you get any error msg on the dash display after changing the lights?
W204 & W211
crystal clear ones on eBay included amber bulbs.
reflector ones on eBay didn't include bulbs.
no, u won't get error msg for switching bulbs...
W203, W211, W212
You only get an error meessage if you swap from incadescent to LED bulbs. The LED bulbs use less power, so the computer thinks the bulb is blown and gives you an error message.
nope - no problems its easy - you just have to push back a little harder than you might think, and pry out the front corner...use a small flat and as wide as possible srew driver if you dont have the poly prys, and wrap it up in a towel or something...if you are uncomfortable cover the bumper / fender too...
im using a yellow 12v
no codes
jake
'05 C230 Kompressor,
BF_JC230 - 5/12/2005 1:52 PM
did yours come with the hole in the side---all the "crystal clear" ones i have been seeing (and the ones on preocarparts) seem to have a big hole in them...what is that? that doesnt seem like it would look professional or original
W204 & W211
that's where the bulb goes in...
it appears like a hole in the middle, but it's not...
only downside is the light doesn't spread throughout the lens...
2005 C230 SS
Thx for the info guys, I'm planning to get the ones on Ebay (The ones with the hole). Prbly have a friend install it for me cuz I'm an idiot!
Here is a picture....and to your point if i were to design the housing i would have done it different as well, but to engineer, tool, and manufacture this - the "hole" is the easiest...the reflector style hides this more if you dont like the look...
anyway here are picts of my front end...
jake
1 - 14 of 14 Posts
