Discussion Starter #2
Yes but several modifications have to be made...
19x8.5 wheel - 7mm-8mm spacer <br> 235/35/19 tires<br> <br> 19x9.5 wheel - 10mm-12mm spacer (not too sure of the exact width. will get back to you)<br> 255/30/19 tires<br> <br> The C has 12mm lug bolts and the CL's take 14mm bolts so you would need to modify the hub to take in 14mm bolts. <br> <br> Good luck and shows us pics if you do it.
Re: Yes but several modifications have to be made...
Thanks VERY much for yr info.<br> One more question: Do I have to roll the rear fender after putting the spacers in? I am afraid putting a 9.5x19 on the rear will rub the fender.
Re: Re: Yes but several modifications have to be made...
see http://forums.mbnz.org/forums/W203/vthread.asp?messid=2215
