i am new on this forum, i have just purchased a Cl500 (2001). there is no sound from the left hand side speakers. I tried adjusting it but when i balance it to left only everthing cuts off.
any ideas. is it bose amp problem or just a wiring problem from the command system.
thanks
I don't see any other option than measuring the setup from speakers to the amplifier. Even if it had the Sound system amplifier, left side alone cannot be gone unless the speakers are all bad on the left side, the amplifier is dead for the left side speakers or the wiring is bad. The head unit connects via fibre to the amp, should be almost impossible to have one side failing anywhere backwards from the amplifier.
