CL600
I got a check engine light notice and engine performance dropped to 6 or 8 cyl. Computer said no malfunction and the light is blinking 3 times on startup and then stops blinking. No unpleasant engine sounds. Anyone experienced this ? :confused:
CL 600 RennTech
Your car may need a test to see any sparkplug was out and need to be replaced. And it's the cheapest round. Diag. test is needed to check to see which engine having poor function.
Happened to my car, only required to change one sparkplug... and back to normal. Good luck!
· Outstanding Contributor - Always Remembered, RIP
Zotye Auto 1.5T T600 2016
Unfortunately the ignigtion coil packs do go wrong, best to have a diagnostic readout done first. If its the newer model with Temic coils, you cannot change one individual coil, you have to change the whole bank of 6. Very expensive sadly, so the diagnostic test is very important. Best of luck from Eric in Cina to Eric in Norway:thumbsup:
