I was wondering if anybody knows the part number for the cigarette socket piece on a 2002 e320. The one I have does not work. I checked the fuses and they are fine, also checked to make sure it is connected properly behind the ash tray and that is secure so I am assuming its the actual socket. The stealership wants $50 so I was wondering if somebody knew the part number or a website where I c an get it cheaper then $50.
Have you checked with test light for power in center of the socket?
210 820 01 53 $34.20 at parts.com
W210 Moderator
best thing to do is either to let the dealer get the part# or you sign up (free)
to MBUSA's EPC database. it's under the CHASSIS, then under PANELLING.
the STICKIES already has a downloadable file very similar to the EPC diagrams
and is listed under Russian Parts Diagrams. between that and the
superseded MB Parts Price List below it, you should have a pretty good idea
of the part # and dealer/retail cost.
EPC however, should pinpoint it based on your VIN whereas the resources
mentioned above only narrow it down to 'likely' instead of 'certainty'.
