1983 300 SD; 2000 E320
I went to plug my radar detector into my lighter and found it "plugged". I pushed down, tried to pry up, but can't get a cavity with contacts to put my plug in. What's the trick? See photo.
Thank you!!!
Depends on the day!
plug it in...it will (should) pop itself. I have gotten them out w/ dental hooks if that doesn't work.
Jonathan
RE: cigarette lighter question - SOLVED
I just discovered that the cig. lighter was unplugged. Very short harness, but I got it back in and now it's fine.
93 190E 2.6; 82 300 SD Turbo
i belive all of my cig lighters are disabled, how? im not entirely sure, i would like to reactive them only because they have other uses like charging stuff. Any idea where they could be disabled at?
Kris
there's a plug underneath the radio which plugs into the back of the ashtray/ lighter unit.
i tried that plug but still no juice, my rear ones are out too, im thinkin something up in the fuse box. But im not sure...
Depends on the day!
Well, double check them..replcae the fuse that feeds the lighter just out of principle. If you have aluminum fuses replace them w/ copper. Who ever decided to manufacture alum. fuses must have Not been thinking.
Let me know if you could use a fuse kit.
Jonathan
