Do you guys know where I can get this cheap it seems like $75 for just a piece of plastic or chrome whatever it is, is kind of expensive
Actually, that one (For_My_Mercedes) is chrome plated brass, so it is high quality and I think worth it (I have that one). If you can find the same thing cheaper, go for it. But, make sure you don't get plastic!BlackHawk - 2/22/2005 11:13 PM
The ones they sell on Ebay for $50 are metal and I bought one, but I am not very happy with it. The metal is very thin (slightly thicker than the wall of a soda can). I actually put a dent in it when installing it (which is just sticking it on with the included two-sided tape) and another one when I pushed against it to close the door.Actually, that one (For_My_Mercedes) is chrome plated brass, so it is high quality and I think worth it (I have that one). If you can find the same thing cheaper, go for it. But, make sure you don't get plastic!
It's been a couple years, but I recall it being pretty substantial weight, and the fit was perfect. You can't tell it from factory. The factory one requires taking apart the tailgate (inside cover) and I do not see the advantage.rudeney - 2/23/2005 10:01 AM
How thick is the on you bought, Greg? I may need to get that one as I hate driving around with dented bling.
Also, as for not buying plastic, note that the OEM part is in fact plastic. I was thinking about just buying that from the dealer. At one time, it was only about $80, but of course takes a little more effort to install.
- RODNEY
I got lots of pictures <b><a href="http://babenj.tzo.com:6971/s4toml/gallery/view_album.php?set_albumName=tailgatechrome" target="_blank">HERE</a></b> including install.ttaleric - 2/23/2005 10:22 AM
Do you have any pictures of it?
If your ML is 2001 and older those pop out rear window was an option if you have a factory 3rd row seat. and from 02 and newer they are standard I think[Did I just discover something new..does the rear windows pop open on the ml.....Did i see that correctly on your photo?I don't think I ever tried that>>>>>>>Thanks
