1980 280e
edit: Look at the last post for latest scrip, this first scrip was just a test, basically for fun.
This changes all the links on the in the main forum index to point to the w123 section (atleast in chrome, should work with firefox (greasemonkey) also), I made it as a project to learn how to write extensions so it's fairly useless, but then I realized it would make a funny april fools joke or something for friend or whatever. Basically just unzip it and drag benzworld.user.js into the webbrowser and then an install prompt will show up.
Code:
run(); // execute's the "run()" function.
function run()
	// Determines if person is surfing benzworld.org then runs functions "a()" and "b()".
	if (document.location.host.match(/www.benzworld.org/))
		a();
		b();
function a()
	//Adds the text "Adjusted for inflation value = ~$50,000 -> ~$71,000 (2010)" to the w123 table cell.
		document.getElementById('f16').innerHTML = document.getElementById('f16').innerHTML + '<small><i>Adjusted for inflation value = ~$50,000 -> ~$71,000 (2010)</i></small>';
function b()
	// Finds all the anchor tags and changes the "href" attribute to point to http://www.benzworld.org/forums/w123-e-ce-d-cd-td/,
	// only works in the forum section for some reason??
		var spanArray = document.getElementsByTagName('a'); //.innerHTML = this.innerHTML + 'W';
		for (var i = 0; i <spanArray.length; i++)
		spanArray[i].setAttribute('href','http://www.benzworld.org/forums/w123-e-ce-d-cd-td/');
1980 280e
Discussion Starter #2 (Edited)
Heres another script, it actually does something usefull, basically it just removes a bunch of clutter from most of the pages (not all it isn't perfect), I think it makes benzworld look more modern and more inline with it's sort of "high tech" graphics. Not going to bother posting the code, it isn't pretty.
1980 280e
Bump, did any one try it out? Anyone try it with grease monkey/firefox? I know the extensions are not super deluxe but nobody has made any extensions for benzword, there must be 1000+ extensions for Reddit.com thou lol.
1980 280e
Learned a couple more tricks, basically the "Automatically retrieve titles from external links" always bugged me so I set it to be unchecked by default, and deleted the whole left side which opens up the forums nicely I think. But still work in progress. As before just unzip and drag into browser.
