Hi all I am new to this forum and I have recently got a Mercedes E280 1998. I would like to look at the kind of options I have on changing into a sportier or multi-functional steering wheel.
Any suggestions will be welcomed and appreciated. Thank you all![:D]
SLK320, MKV Jetta TDI, Mini Cooper S, Lincoln Mark LT
You can switch to the wood wheel and airbag from the R170 SLK for a fresher look. Going to the multifuntion wheel require a different contact ring and wiring in the steering column.
Thanks! If I do want to go the multi-function route is it possible? If so which ones would you recommend?
