1993 300SD w140
Should be same as my 1993 300SD. You move the clip forward on the dipstick and remove dipstick. There are 2 lines on the dipstick - Hi and low marks. Ideally you need to check after driving at least 20 miles to heat up fluid. Fluid expands alot. Most people overfill transmission. Check after driving on turnpike etc.
Engine needs to be running and car in park while you check level. Do not go over the hi mark and insert dipstick all the way. Hope this helps.
