It is about 1/4" passed the full mark. I don't know if it is a pint or not.I would. From what I was told by a MB tech a "little" high is worse than a "little" low.
I needed something to do tomorrow any way.that's not bad. start by sucking out 100ml if it's only 1/4 of inch over full mark. i bet that will do it.
I am sure EBAY has them, but I made my own . I think there is a sticky about it. I used 1/8" plastic coated wire from the hardware store. It is about 3' long, cost maybe $3.Where do you get the tool to check the level?
I was doing a fluid and filter changeShouldn't the question "Why did you need to add fluid?" be asked here?
Seems to me that the level should never drop significantly enough to add a quart or so unless there's a problem that should be addressed.
Am I wrong?
