1 - 10 of 10 Posts
Hi everyone I have 2010 glk350 the check engine is on and shows like 10 codes kind of related to same thing something with air the codes arep0448,p0414,p0458,p0031,p0057,p0037,p0051 I change the purge valve didn’t work I really hope to get some answers from here and will appreciate any advices
Thank you very much I will definitely check it The battery voltage was low so I did charge it I don’t know if that makes a difference tho ?
If voltage gets too low, it can trigger these types of codes. How old is the battery, and how many miles on the car?
I’m not sure how old is my battery I bought the car last year in July car has 81k on right now should I buy new battery and try?
Well, your alternator should be good with that mileage. Sometimes there is an installation sticker on the battery; if it’s over 5 years I would just replace it. Otherwise, charge it up, clear codes and keep an eye on it.
I did changed the battery but the same codes came back again do you think may be oxygen sensor went ?
If you reset the codes using the code reader and they still came back, I would do further diagnosis before throwing money at parts. The codes are for different systems, with the low voltage being the common item among them.
1 - 10 of 10 Posts
