1998 C280
Hello all,
I replaced my gas cap in an attempt to make the check engine light go off after the emissions inspection station said it took 4 attempts to get the old gas cap to pass. Does the light go out automatically (hopefully) or how do I reset it? Oh yeah, I failed to mention that this situation is on a 98 C280.
Other silly questions to follow.
'99 2.3L Kompressor
If the gas cap was the problem, yes, the light will reset itself after a while. You could also stop by an AutoZone and use their free code reader to clear the code or disconnect the battery for a few minutes (but you will have to resync the windows and sunroof - directions in your manual).
W201, W202, W203, W204, W205 Moderator
Amethyst 2001 C320 with 351,000 miles
Most people suggest that you disconnect your battery, but they're wrong...you don't have to do that. Afterall, it's a pain to re-sync everything and re-code your radio.
Instead, pull out fuse #32 for about 30 seconds, then put it back in. Start the car up and the light should be off!
I have a 1994 C280, so the fuse # may be different on your car, but look for a fuse labeled something like "Engine Diagnostic".
