2002 Mercedes ML320
If you read my original post re: ACCELERATION PROBLEMS WITH 0'2 ML320 , well now the check engine light went off and it seems to be running "ok". I have another appt with service on Tuesday for a diagnosis. I had a diagnosis done last week at a independent repair shop.
The service person I talked to at Mercedes said this is very common and the computer basically has already read the problem and has stored it.
Have any of you had this happen?
Thanks:D
· Outstanding Contributor
2006 ML500 2002 ML320
Thanks:D
Yes it is a common problem with any car. But when you had it diagnosed by the independent, what did he tell you was the problem and did you get the code number(s)?
