hi my car its a c230 2006, i just get the info from the service dealer and give me this info:
short test vehicle, retreived codes 0750 2096 0746 2092.
somebody knows what does mean every code??
any recomendation for fix my car?
thank you
thanks for the page, now anybody can give any advice with this, because in the dealer told me that i have to change the spark plugs, coils plugs and the 2 oxigen sensor on the right exaust, please any advice will help.
thank you
2002 C32 AMG
Mileage? When you start to run into many codes causing CEL it could be faulty ECU due to oil/water contamination. It's a known issue one of the sensors (forgot which one) can leak oil, and that oil can seep in all the way to the ECU. Probably not your problem though... Replace spark plugs first if your around or above 100k miles. Coil packs don't tend to go bad. Especially all of them... Oxygen sensors don't tend to go bad either although they certainly can. You running premium unleaded or regular?
Discussion Starter · #5 ·
the mileage its about 61000, always since i bought the car and its about 4 months ago i use premium mobil.
2002 C32 AMG
In that case start with just the oxygen sensors... Have you cleared the codes to see if they return?
Discussion Starter · #7 ·
the codes are been cleared, one think that i notice its the spark plugs and air filters are the same as manufacturer, means this car with 60k it not been made any maintenance before, do you think could be for this reason the codes shows?? before i cleared the codes, the scan show me 4 codes, P0173 P0170 and repeat it twice, do you know why??
thanks
