So a week ago, I pulled out my (replaced october) O2 sensor, only to find it was bad and causing my CEL to come on. I went and replaced it to the tune of $130 and it ran smoothly with no warning lamps. Just now after I went out for a jaunt to try out my new Euro headlights, suddenly the light comes on. Diagnostic tool again said 17 blinks=f*cked O2 Sensor.
Did it just eat an o2 sensor in 135 miles? Should I be looking elsewhere for faults in the wiring? Or are my EGTs somehow getting so high they're cracking the ceramic inside the sensor?
1985 500sel and 500sec 2012 E63 1989 Porsche 911
i wonder if my car even has a cel
1993 300TE, 1995 E320 Wagon
I'd check the connections first off. I don't know if there's a fuse that controls power to it-- could it be something like that? I highly doubt that it "ate" an O2 so quickly-- unless it was faulty to start with. Did you get a Bosch OEM one or something else? I recall that you can also use the same type for a Ford Mustang (cheaper to replace). If you have the OEM Bosch, it might just be that the connection under the passenger rug never got completely connected (I recall a pretty decent *click* when I pulled mine out a couple of years ago).
No sir, I made very sure I got the OEM Bosch 13146 unit. I'll take a look and double-check my connections. I hope the unit isn't defective, because the one I pulled out was a defective unit my mechanic put in.
Just to make sure, I wasn't implying a cheapo replacement or that you might be cutting corners-- I have a non-OEM unit in there myself (a four-wire unit that works just fine). At the time I was replacing mine, I read here on this forum that the OEM Bosch was not worth the extra $60-$80-- and a four-wire unit gives a faster/more accurate signal to the engine controls...
That being said, I hope it's just your connections... I will have to dig some, but I know that there is a test procedure to check on the O2 operations. Gimme a bit and I'll try to look it up.
Unfortunately no. The connections were solid. My dad, however did a bit of research and found that a faulty EGR valve would damage an O2 sensor, as well as produce several other symptoms we're experiencing. I pulled off the EGR valve and sure enough, it wouldn't hold vacuum at all. So I've got some new parts coming in the mail.
