My 1999 Mercedes S500 started shaking and check engine light came on while I was driving today. Car shakes noticeably when idled and when driven. Im thinking motor mounts but can anyone else give me some ideas of what to look for?
Check the OBDII codes under the steering wheel. Motor mounts could be bad but they wouldn't trigger the CE light.
1997 S500
You lost an ignition coil. Go get a cheap code reader, plug it in and figure out which one is bad. There are eight-one for each cylinder. The code will be P300 through P308 most likely. Each one refers to a specific cylinder. Go here Your Parts Search Returned 1 Part(s) and order the coil and the spark plug connector. Problem solved. My S500 has 145,XXX miles on it and I've replaced 7 coils. You might as well oder an extra to have on hand. Good luck
Paul
1999 S500 (W140)
Paul
this sounds about right :D
Dear friend I has Mercedes S 320 model 1998: I have problem in it
• When I need to start up and change the gear from N to R or from N to D there is little shaking
• At driving if I slow down my speed for bumpy then press the fuel to speedy the engine shaking continually until I stop the car and switch of the car and restart again the engine bake normally and stable
• Pleas tell what’s the reason.
2004 S500
pchansen1 - I just want to say you are what these forums are all about! Great help on that shaking problem for that guy. I will feel less nervous when that happens to me now since I know the issue. Thanks!
