2000 E430 4matic
Hi Everyone! I have a 2000 E430, and my check engine light has just come on. I've noticed the car seems to be revving a little higher than normal, and shifting doesn't seem to change it, or changes very little. Is there a way of retrieving the codes without a reader? I live in a very remote area and the nearest MB is 5 hours away. Any help will be appreciated!
Thanks!
'01-E320 & 02-ST2
Thanks!
None at all. You can order a basic reader online for under $20 from Amazon, though I don't know what it would cost up there with shipping, etc. All you need is an OBD-II reader (it will also clear codes). If you have an android phone you can buy the bluetooth OBD-II interface and use the TORQ app, but that will be more costly than a basic reader.
In the states some parts stores will read codes for free, you don't need a dealer. Or if you have an indy shop near you they can do it as well.
I would try to drive the car as little as possible until you can get the codes read. While it's not a critical situation, there are some things that can overheat and damage the cats, and those are expensive to replace.
Good luck.
'99 E430 '98 C230
Autozone and Advance and Oreillys will check it for free and give you a print out with the possible cause and code for the CE light.
