1 - 9 of 9 Posts
1996 S-500 white
Check Eng Light On My 99 SL 500
Here Are The Codes
P0130*O2 Sensor Circuit Malfunction (Bank 1 Sensor 1)
P0170*Fuel Trim Malfunction (Bank 1)
P0173*Fuel Trim Malfunction (Bank 2)
Any Help ??
Harley03joe :Smoker:
Check and clean your MAF
(don't confuse it with MILF:D)
00 SL500 SOLD, 05 SL600 Sport, 09 Silverado 4x4 LTZ,SOLD '15Silverado LTZ 6.2 8Speed John Deere 318
REPLACE the Mass Air Flow Sensor, You can clean it,but, You WILL be replacing it shortly!!!!!! Pay Me NOW or Pay Me Later!!!!!!
2001 SL500 / 2004 Dodge Ram 3500 HO CTD / 2010 Subaru Outback
x2. And be sure that all of the vacuum lines, etc. in the area are correctly and securely attached when you're all done with the replacement. Don't ask me how I know this ...:rolleyes:
1998 silver 500sl
Cleaned mine and it still failed. Connected to 12volt power and it worked. Took a file and cleaned to post, now it works fine.
1996 S-500 white
Replace The Map
Replace The Map , It Was A Friend On Mines Car , I Guess All Is Ok Now
Thank You All
1 - 9 of 9 Posts
