C200 -98 classic AUT 280000km
I have a problem with my abs/asr lights being constantly on and the systems not working. Both lights are on immediate after start and always stay on. The lights used to go out before, randomly, but now they are always on.
I have checked fuses, changed the break pedal switch and cleaned both front sensors. Did not find any sensors at the rear wheels so I suppose there is one sensor on the axle for both.
the rpm and km/h meters work fine = the sensor on the rear wheels is ok?
1. the cruize control does not work
2. the kickdown does not work (yes im sure this is the reason, it worked fine whenever the lights would go off.. it shifts down when i press the pedal, but when it reaches high rpm it doesn't shift up)
3. and now after me "cleaning" the sensors (using wd-40 electric cleaning compound) the doors don't automatically lock above 10km/h (they did prior cleaning, even though the cruize, kickdown didn't)
does these symptoms point to a abs sensor? do they point to a specifik, ie the front left?
also read that you can check with a multimeter if the sensor is working correctly by reading the resistance. But where would you connect the multimeter since it is a enclosed system as far as I can see? Included two pictures.
http://public.openmindedprojects.com/ABSSensor_Givare.jpg
http://public.openmindedprojects.com/ABSSensor_Kontakt.jpg
CAUTION - THE PICTURES ARE BIG no modems
